AnoleX
AnoleX 3020-Evo
Entry-level all-metal CNC with a 300W spindle
AnoleX no longer sells this model, but it remains fully supported in Easel. The 3020-Evo has a 287 x 196 x 73 mm working area, a 300W spindle upgradeable to a 65mm router, and dual steel linear guide rails on the X and Z axes.
The 3020-Evo's spindle is a 300W unit, and AnoleX does not publish a max RPM for it, so check the rating plate on your spindle before you start. A spindle this size is light duty: it loses torque fast once you push speed and load together, so keep the feed rate doing the work rather than cranking the spindle. The dual steel linear guide rails on X and Z keep the machine accurate, but this is still a compact desktop router, not a heavy industrial frame. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The 3020-Evo falls short of that bar, so take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. AnoleX does not publish a max spindle RPM for the 3020-Evo, so check your spindle's rating plate and use that number if it is lower than 16,000. With the bit maker's 0.025mm per tooth (0.0010 in): RPM x 0.025 x 2 = feed rate in mm/min. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
287 x 196 x 73 mm
300W spindle, upgradeable to 65mm router
Dual steel linear guide rails on X and Z axes with anti-backlash nut block
AnoleX no longer sells the 3020-Evo, but it stays fully supported in Easel. It connects through the free Easel Driver: install the driver on your Mac or Windows computer, plug the machine in over USB, and Easel talks to it in real time. You design in the browser, Easel generates the toolpaths, and the Carve button walks you through homing, zeroing, and starting the cut. Pick 3020-Evo from Easel's machine menu during setup and the canvas is sized to the machine's 287 x 196 x 73 mm working area, so your preview matches what the machine can actually cut.
