AnoleX
AnoleX 3060-Evo Max
All-metal CNC with an 800W trim router and a 300 x 600mm bed
AnoleX 3060-Evo Max machine photo
The 3060-Evo Max has a 300 x 600 x 73 mm effective processing area on a 300 x 600 mm bed. It runs an 800W trim router (6-speed, 8,000 to 24,000 RPM) on a 65mm mount, MGN-15 dual linear guides and T8 lead screws on all three axes, and Nema 17 steppers rated 650 mN·m.
The 3060-Evo Max's 800W trim router runs 8,000 to 24,000 RPM across its six speed settings, covering the full range of the chart below and then some. Its MGN-15 dual linear guides and T8 lead screws on all three axes give it real rigidity for a desktop router, but the 3060's longer 600mm gantry span has more room to flex than the smaller 3030 format, and a trim router is still lighter duty than an industrial spindle. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Treat this machine as capable of moderate depth per pass in softer materials, but back off in hardwood or aluminum and on cuts near the far end of the gantry: push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM, and this router's 24,000 RPM top speed covers it, so run 16,000. With the bit maker's 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
300 x 600 x 73 mm (bed size 300 x 600 mm)
800W trim router (65mm), 6-speed, 8,000 to 24,000 RPM
Nema 17, 650 mN·m torque
MGN-15 dual linear guides and T8 lead screws on all axes
The 3060-Evo Max connects over USB through the free Easel Driver: install the driver on your Mac or Windows computer, plug the machine in, and Easel talks to it in real time. You design in the browser, Easel generates the toolpaths, and the Carve button walks you through homing, zeroing, and starting the cut. Pick 3060-Evo Max from Easel's machine menu during setup and the canvas is sized to the machine's 300 x 600 x 73 mm working area, so your preview matches what the machine can actually cut.
