Carbide 3D
Carbide 3D Shapeoko 4
Best-value desktop CNC router in three sizes, V-wheel and belt drive
Carbide 3D Shapeoko 4 machine photo
The Shapeoko 4 comes in three sizes: Standard (17.5 x 17.5 x 4 in), XL (33 x 17.5 x 4 in), and XXL (33 x 33 x 4 in). It uses a 65mm trim router as a spindle (not included, upgradeable to the Carbide VFD Spindle), Heavy-Duty V-wheels on 15mm belts for X/Y, and a leadscrew-driven Z-Plus Z-axis with heavy-duty linear bearings. Takes about 2-3 hours to assemble.
The Shapeoko 4 ships without a spindle: you supply a 65mm trim router (the Carbide Compact Router or a compatible router like the Makita RT0701C), or upgrade to the Carbide VFD Spindle, so your actual RPM depends on what you install. Heavy-Duty V-wheels on 15mm belts and a leadscrew Z-Plus Z-axis give it a solid base for a desktop machine, but it's not a rigid industrial frame, especially on the larger XL and XXL sizes. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The Shapeoko 4 falls short of that bar, and the fix is simple: take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM: since this machine ships without a spindle, check your router's plate or speed dial for its actual RPM and use that number instead. With the bit maker's 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
Standard: 17.5 x 17.5 x 4 in; XL: 33 x 17.5 x 4 in; XXL: 33 x 33 x 4 in
Not included; uses a 65mm trim router (Carbide Compact Router or compatible, e.g. Makita RT0701C); upgradeable to the Carbide VFD Spindle
Heavy-Duty V-wheels on 15mm belts (X/Y); leadscrew Z-axis (Z-Plus) with heavy-duty linear bearings
Carbide Motion control software
The Shapeoko 4 runs Carbide Motion control software. The manufacturer's page does not use the word GRBL to describe it. Easel's real-time carving works with GRBL controllers over USB, so this machine's Easel Driver connection is not confirmed here. It is selectable in Easel's menu as 'Shapeoko 4,' 'Shapeoko 4 XL,' or 'Shapeoko 4 XXL' depending on size, which sizes the canvas to that size's working area. A human should confirm the actual firmware and connection method before publish.
