Carbide 3D
Carbide 3D Shapeoko Pro
Production-ready CNC in three sizes, linear-rail upgrade over Shapeoko 4
Carbide 3D Shapeoko Pro machine photo
The Shapeoko Pro ships without a spindle: you supply a 65mm trim router (the Carbide Compact Router recommended, or any 65mm router like the Makita RT0701C), or upgrade to the Carbide VFD Spindle, so your actual RPM depends on what you install. 15mm linear rails on 15mm belts give it more rigidity than the Shapeoko 4's V-wheels, and the leadscrew Z-Plus Z-axis holds up well, but it's still a desktop-class machine, not an industrial one, especially on the larger XL and XXL sizes. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Push too deep on the Shapeoko Pro and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material, so take shallower passes and work up. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM: since this machine ships without a spindle, check your router's plate or speed dial for its actual RPM and use that number instead. With the bit maker's 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
Standard: 17.5 x 17.5 x 4 in; XL: 33 x 17.5 x 4 in; XXL: 33 x 33 x 4 in
Not included; uses a 65mm trim router (Carbide Compact Router recommended, or any 65mm router e.g. Makita RT0701C); upgradeable to the Carbide VFD Spindle
15mm linear rails on 15mm belts (X/Y, more rigid than Shapeoko 4's V-wheels); leadscrew Z-axis (Z-Plus) with heavy-duty linear bearings
Carbide Motion control software
The Shapeoko Pro runs Carbide Motion control software. The manufacturer's page does not use the word GRBL to describe it. Easel's real-time carving works with GRBL controllers over USB, so this machine's Easel Driver connection is not confirmed here. It is selectable in Easel's menu as 'Shapeoko Pro,' 'Shapeoko XL PRO,' or 'Shapeoko XXL Pro' depending on size, which sizes the canvas to that size's working area. A human should confirm the actual firmware and connection method before publish.
