3018-class machines typically ship with a small brushed spindle motor, often in the 24V to 36V range with no published RPM chart, so check your own spindle's plate or listing for its actual top speed before picking a number off the chart. These are light, compact machines built on small aluminum extrusion and leadscrews, not rigid production tools, so depth per pass is limited by the machine's own stiffness. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. A small 3018 falls well short of that bar, and the fix is simple: take shallow passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. Most 3018-class spindles do not reach that speed, so check your spindle's own plate or listing for its actual maximum and use that number instead if it is lower. With the bit maker's 0.025mm per tooth (0.0010 in), at a spindle speed of 16,000 RPM: 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. Scale the feed down proportionally if your spindle's real top speed is lower. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on similar 3018 machines. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
GRBL is the standard controller across nearly every 3018-class machine, and connects over USB. If your machine runs GRBL, connect through the free Easel Driver: install it on your Mac or Windows computer, plug the machine in over USB, and Easel talks to it in real time. You design in the browser, Easel generates the toolpaths, and the Carve button walks you through homing, zeroing, and starting the cut. Pick 3018 from Easel's machine menu and the canvas is sized to the class's typical working area. Because this entry covers many different sellers' machines rather than one validated product, check your own machine's actual working area and controller against its listing or manual before you carve.
