FoxAlien
FoxAlien Masuter 3
Final Sale: entry-level CNC with a 775 spindle
Final Sale: FoxAlien is retiring this model, but it remains fully supported in Easel. The Masuter 3 has a 400 x 400 x 95 mm working area, a 775-type spindle (10,000 RPM), and 1.3 A stepper motors (0.25 Nm torque).
The Masuter 3's 775 spindle tops out at 10,000 RPM, below most of the chart. Small brushed spindles lose most of their torque under top speed, so leave it at 10,000 for everything and control the cut with feed rate. If acrylic starts to melt, speed the feed up instead of slowing the spindle. Skip aluminum on this spindle except for light engraving. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. A light machine like this one falls short of that bar, and the fix is simple: take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
400 x 400 x 95 mm
775 spindle
1.3 A, 0.25 Nm
Lead screws; steel wheels on all axes, linear rails on Z
FoxAlien is retiring the Masuter 3, but it stays fully supported in Easel. It connects through the free Easel Driver: install the driver on your Mac or Windows computer, plug the machine in over USB, and Easel talks to it in real time. You design in the browser, Easel generates the toolpaths, and the Carve button walks you through homing, zeroing, and starting the cut. Pick Masuter 3 4040 from Easel's machine menu during setup (or Masuter 3 4080 if you have the extension kit) and the canvas is sized to the machine's 400 x 400 x 95 mm working area, so your preview matches what the machine can actually cut.
