FoxAlien
FoxAlien XE-Ultra
Flagship large-format CNC with ball screws and linear rails
The FoxAlien XE-Ultra is the flagship large-format CNC with an 840 x 840 x 120 mm working area, 16mm (XY) and 12mm (Z) ball screws with HG-15 linear rails, and 60-86mm closed-loop stepper motors (2.6 N.m). Spindle and spoilboard are not included with the base machine.
The XE-Ultra ships without a spindle. Most owners install a 65mm trim router or FoxAlien's 1.5kW VFD spindle, and either one can hit every speed in the chart, so set your RPM straight from it. If plastic starts to smear, slow the spindle down or speed up the feed. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Few hobby machines check every one of those boxes, and the fix is simple: take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM, and the bit maker's chart gives 0.025mm per tooth (0.0010 in). Feed = 16,000 x 0.025 x 2 = 800 mm/min (31 in/min), well under this machine's 5,000 mm/min (197 in/min) maximum. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
840 x 840 x 120 mm
Not included; fits a 65mm router or 1.5kW VFD bundle
NEMA 23 closed-loop, 2.6 Nm
16mm (XY) / 12mm (Z) ball screws, HG-15 linear rails
The XE-Ultra connects to Easel through the free Easel Driver. Install the driver on your Mac or Windows computer, plug the machine in over USB, and Easel talks to it in real time. You design in the browser, Easel generates the toolpaths, and the Carve button walks you through homing, zeroing, and starting the cut. Pick XE-Ultra from Easel's machine menu during setup and the canvas is sized to the machine's 840 x 840 x 120 mm working area, so your preview matches what the machine can actually cut.
