FoxAlien
FoxAlien XE-Ultra Core
Compact flagship platform for precision carving
In the Easel menu this machine is sold as the 1.5kW VFD spindle bundle, and that spindle can hit every speed in the chart, so set your RPM straight from it. If plastic starts to smear, slow the spindle down or speed up the feed. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Few hobby machines check every one of those boxes, and the fix is simple: take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM, and the bit maker's chart gives 0.025mm per tooth (0.0010 in). Feed = 16,000 x 0.025 x 2 = 800 mm/min (31 in/min). For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
440 x 440 x 120 mm
Sold as 1.5kW VFD spindle bundle
NEMA 23 closed-loop, 2.6 Nm
16mm (XY) / 12mm (Z) ball screws, HG-15 linear rails
The XE-Ultra Core connects to Easel through the free Easel Driver. Install the driver on your Mac or Windows computer, plug the machine in over USB, and Easel talks to it in real time. You design in the browser, Easel generates the toolpaths, and the Carve button walks you through homing, zeroing, and starting the cut. Pick 'XE-Ultra Core with 1.5KW VFD Spindle Bundle Kit' from Easel's machine menu during setup and the canvas is sized to the machine's 440 x 440 x 120 mm working area, so your preview matches what the machine can actually cut.
