Lunyee
Lunyee 3018 Pro Max
Entry-level CNC router with a 500W spindle and steel lead screws
Lunyee 3018 Pro Max machine photo
The 3018 Pro Max is Lunyee's entry-level all-metal CNC router, with a 300 x 180 x 80 mm working area, a 500W spindle (0 to 12,000 RPM), and Nema 17 stepper motors (1.68 A, 0.55 Nm torque) driving T8 stainless steel lead screws and 12mm hardened steel linear rods.
The 3018 Pro Max's 500W spindle runs from 0 to 12,000 RPM, near the middle of most chip-load charts, so you have real range to match bit and material. Its lead-screw drive and hobby-scale frame are light duty, not a heavy industrial gantry, so depth per pass is where you have to be conservative. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. This machine falls short of that bar, so take shallower passes: push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM, but this spindle tops out at 12,000 RPM, so run 12,000. With the bit maker's 0.025mm per tooth (0.0010 in): 12,000 x 0.025 x 2 = 600 mm/min (24 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
300 x 180 x 80 mm (11.8 x 7.1 x 3.15 in)
500W spindle
Nema 17, 1.68 A, 0.55 Nm
T8 stainless steel lead screws with 12mm hardened steel linear rods
The 3018 Pro Max connects over USB through the free Easel Driver: install the driver on your Mac or Windows computer, plug the machine in, and Easel talks to it in real time. You design in the browser, Easel generates the toolpaths, and the Carve button walks you through homing, zeroing, and starting the cut. Pick 3018 Pro Max from Easel's machine menu during setup and the canvas is sized to the machine's 300 x 180 x 80 mm working area, so your preview matches what the machine can actually cut.
