Lunyee
Lunyee CNC 1325 Pro
Large-format industrial CNC router with a Mach3 control system
Lunyee CNC 1325 Pro machine photo
The CNC 1325 Pro is Lunyee's large-format industrial router, with a 1300 x 2500 x 200 mm working area, a 2.2, 3, or 5.5kW spindle (0 to 24,000 RPM), and 86-frame stepper motors. It drives the X and Y axes on rail and rack, and the Z axis on rail and ball screw.
The CNC 1325 Pro's 2.2 to 5.5kW spindle spins up to 24,000 RPM, above most of the chip-load chart's range, and its rack-and-rail X/Y drive with a ball-screw Z axis is built for a heavy industrial gantry, not a hobby desktop. A machine this rigid and this powerful can cut as deep as the bit is wide in a single pass: that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration, and this one has all four. Even so, push a pass past what the flute geometry and material can clear and it will deflect and chatter, leaving scalloped edges, or rub instead of cutting and burn the material, so build up from a conservative first pass. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM, well within this spindle's range, so run 16,000. With the bit maker's 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
2.2 / 3 / 5.5 kW water-cooled spindle
X/Y: rail and rack; Z: rail and ball screw
Mach3
Lunyee lists the CNC 1325 Pro's control system as Mach3, not GRBL. Easel's real-time carving connects to machines over USB through GRBL controllers, so the Easel Driver does not connect to this machine as sold. It is selectable in Easel's machine menu as CNC 1325 Pro, which sizes the canvas to its working area, but confirm with Lunyee and test the actual connection before recommending this machine to a customer who wants to carve with Easel.
