The M2 is a 4ft x 8ft x 3.8in (1.22m x 2.44m x 9.65cm) cutting volume machine, up to 32 sq ft, made by MakerMade as the successor to the original Maslow 2 design. It runs on industrial drive motors on all three axes with 11ft chains (15ft chains available), an all-metal Z-axis, and an Arduino DUE v1.2 control shield. It ships without a router: the 65mm metal router clamp standard (71mm or 91mm clamps available) fits bits from 1/8in to 1/2in depending on the router used.
MakerMade does not publish a spindle RPM for the M2 since you supply your own router, so check the plate on yours before you start. The M2 itself caps at 40 in/min (17mm/s) maximum cutting speed regardless of what the chip-load math returns, so treat that as a hard ceiling. A truly rigid, powerful setup can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a frame that will not flex, and enough mass to soak up vibration. Chain-driven machines like the M2 fall short of that bar, so take shallow passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. MakerMade does not state a spindle RPM for the M2 since you supply your own router, so check the plate on yours and use its actual top speed in place of 16,000 if it is lower. With the bit maker's 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed, but the M2 itself caps at 40 in/min (17mm/s, roughly 1,020 mm/min (40 in/min)) maximum cutting speed, so stay under that regardless. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The M2's spec sheet lists its firmware as GBRL 1.1g, an apparent manufacturer typo for GRBL 1.1g, running on an Arduino DUE v1.2 control shield; treated here as GRBL. It connects over microUSB through the free Easel Driver: install the driver on your Mac or Windows computer, plug the machine in, and Easel talks to it in real time. You design in the browser, Easel generates the toolpaths, and the Carve button walks you through homing, zeroing, and starting the cut. Pick M2 from Easel's machine menu during setup and the canvas is sized to the machine's 4ft x 8ft x 3.8in cutting volume.
