Millright CNC
Millright CNC Carve King 2
Entry-level CNC kit with GRBL control and a Makita router mount
Millright CNC Carve King 2 machine photo
The Carve King 2 has about a 17.25 x 17.25 x 4 in working area, trapezoidal stainless lead screws with POM anti-backlash nuts and V-channel rails with precision-turned Acetron V wheels on every axis, and NEMA 17 stepper motors with dual drive on the Y axis. It ships with a mount for the Makita RT0701C router, but the router itself is not included.
The Carve King 2 doesn't come with a router, so its top RPM depends on whatever you mount to the Makita RT0701C-pattern holder, check that unit's rating plate against the chart rather than assuming a number. Its build, stainless lead screws and V-channel rails with Acetron V wheels, is a light hobby frame, not a heavy industrial one. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The Carve King 2 falls short of that bar, so take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. The Carve King 2 has no bundled router, so check the RPM rating on whatever you mount and use its actual number if it differs. With the bit maker's 0.025mm per tooth (0.0010 in), at 16,000 RPM: 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
Mount for Makita RT0701C router (router not included)
NEMA 17, dual drive on Y axis
Trapezoidal stainless lead screws with POM anti-backlash nuts on every axis; V-channel rails with precision-turned Acetron V wheels and double shielded bearings
The Carve King 2 connects over USB through the free Easel Driver: install the driver on your Mac or Windows computer, plug the machine in, and Easel talks to it in real time. You design in the browser, Easel generates the toolpaths, and the Carve button walks you through homing, zeroing, and starting the cut. Pick Carve King 2 from Easel's machine menu during setup and the canvas is sized to the machine's 17.25 x 17.25 x 4 in working area.
