Millright CNC
Millright CNC M3
Compact CNC kit with a bundled Makita router and GRBL control
Millright CNC M3 machine photo
Millright CNC no longer sells this model, but it remains fully supported in Easel. The M3 has an over 260 x 260 x 50 mm (10.25 x 10.25 x 2 in) working area, a bundled Makita RT0701C router, 9mm fiberglass-reinforced GT2 timing belts on X and Y with V-slot rails, a belt-driven Z axis on linear rods for fast lifts, and NEMA 17 stepper motors.
The M3 ships with a Makita RT0701C router, but Millright CNC doesn't publish its RPM on the product page, check the speed dial on the router itself against the chart. Its GT2 timing belts on X and Y and belt-driven Z axis make it a light, fast machine, not a rigid industrial one. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The M3 falls short of that bar, so take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. The M3's bundled Makita router has no published RPM, so check its speed dial and use that number if it differs from 16,000. With the bit maker's 0.025mm per tooth (0.0010 in), at 16,000 RPM: 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
Makita RT0701C router (included)
NEMA 17
9mm fiberglass-reinforced GT2 timing belts on X/Y; V-slot rails with acetal V wheels; linear rods with linear bearing blocks; belt-driven Z axis for fast lifts
Millright CNC no longer sells the M3, and had stopped taking new orders for it before retiring the listing, but it stays fully supported in Easel. It connects over USB through the free Easel Driver: install the driver on your Mac or Windows computer, plug the machine in, and Easel talks to it in real time. You design in the browser, Easel generates the toolpaths, and the Carve button walks you through homing, zeroing, and starting the cut. Pick M3 from Easel's machine menu during setup and the canvas is sized to the machine's 260 x 260 x 50 mm working area.
