Millright CNC
Millright CNC Mega V Pro
Large-format CNC with a pre-assembled Masso G3 Touch control system, two working-area sizes
Millright CNC Mega V Pro machine photo
The Mega V Pro covers two sizes on one build: Standard at 19 x 19.6 x 6 in (494 x 500 x 152 mm, about 5.5 in gantry clearance) and XL at 35 x 35.4 x 6 in (888 x 900 x 152 mm, about 5.5 in gantry clearance). It runs a 2HP air-cooled ER20 spindle (6,000 to 24,000 RPM), closed-loop stepper motors with encoders on rack-and-pinion X/Y drive and a trapezoidal lead screw Z axis, and MGN15 linear rails on every axis. It comes pre-assembled and pre-tested: mount the control stand, plug it in, and start machining.
The Mega V Pro's 2HP air-cooled spindle runs 6,000 to 24,000 RPM, well above most of the chart below, so leave it at the chart's recommended speed and control the cut with feed rate. Its closed-loop steppers with encoders, rack-and-pinion X/Y drive, and MGN15 linear rails on every axis are built for real rigidity. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration, and the Mega V Pro is built to that bar. Even so, push a pass past what the flute geometry and material can clear and it will deflect and chatter, leaving scalloped edges, or rub instead of cutting and burn the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM, well within this spindle's 6,000 to 24,000 RPM range, so run it at 16,000. With the bit maker's 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
Standard: 494 x 500 x 152 mm (19 x 19.6 x 6 in), about 5.5 in gantry clearance; XL: 888 x 900 x 152 mm (35 x 35.4 x 6 in), about 5.5 in gantry clearance
2HP air-cooled ER20 spindle, G-code controllable, max 1/2 in tool shank
Closed loop with encoder; X 283 oz-in, Y 566 oz-in, Z 283 oz-in torque
Closed-loop motors with rack and pinion (20 diametral pitch, hardened steel pinion) on X/Y; closed-loop motor with trapezoidal lead screw and dual anti-backlash nut on Z; MGN15 linear profile rails on X/Y/Z
Masso G3 Touch (15in touch screen, standalone)
The Mega V Pro ships with an industrial Masso G3 Touch standalone control system with a 15in touch screen; no GRBL option is offered on this machine's product page. Easel's real-time carving connects to machines over USB through GRBL controllers, so the Easel Driver does not connect to the Mega V Pro as sold. It is selectable in Easel's machine menu as 'Mega V Pro' (sized to the 19 x 19.6 x 6 in working area) or 'Mega V Pro XL' (sized to the 35 x 35.4 x 6 in working area); the matching '(non-GRBL)' menu entries appear to be naming duplicates of the same Masso-only machine rather than a separate GRBL SKU. Confirm the actual connection behavior with Millright CNC before recommending this machine to a customer who wants to carve with Easel.
