Millright CNC
Millright CNC Power Route
Mid-size CNC with a bundled DeWalt router
Millright CNC Power Route machine photo
Millright CNC no longer sells this model, but it remains fully supported in Easel. The Power Route has about a 25 x 25 x 5 in working area, a 120V, 2.25 horsepower DeWalt DWP618 router, 16mm supported linear shaft rails on X/Y and a 12mm supported linear shaft rail on Z, and NEMA-class stepper motors. Millright CNC's archived page for this model does not state a controller or firmware.
The Power Route's 120V, 2.25 horsepower DeWalt DWP618 router doesn't have a published RPM on this page, check the router's own speed dial against the chart. Its 16mm/12mm supported linear shaft rails give it a solid mid-size frame, a step up from Millright's smaller belt-driven kits, but it is still a router-powered desktop machine. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Build up depth per pass gradually on this machine. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. The Power Route's DeWalt router has no published RPM on this page, so check its speed dial and use that number if it differs from 16,000. With the bit maker's 0.025mm per tooth (0.0010 in), at 16,000 RPM: 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
25 x 25 x 5 in
120V, 2.25 HP DeWalt DWP618 router (included)
X 540 oz-in, Y 540 oz-in, Z 270 oz-in torque; 5.6A/phase max driver current
16mm supported linear shaft rails on X/Y; 12mm supported linear shaft rail on Z
Millright CNC's archived page for the Power Route does not state a controller or firmware. The company's earlier kits (Carve King, Carve King 2, M3) all shipped with GRBL, so GRBL is likely here too, but that isn't confirmed on the page. Easel's real-time carving works with GRBL controllers over USB. This machine is selectable in Easel's menu as 'Power Route,' sized to its 25 x 25 x 5 in working area. Confirm the controller before publishing connection instructions.
