Full-size CNC with ball screws and a choice of GRBL or Masso control
The Power Route Max has a 1275 x 1275 x 158 mm (50 x 50 x 6.25 in) working area with 5.5 in gantry clearance. It runs 16mm precision ball screws on X and Y (dual on Y with an auto-squaring gantry) and a 12mm precision ball screw on Z, and ships with a router mount for the DeWalt DW618 (router not included) or an optional 1.5kW air-cooled, 2.2kW water-cooled, or 2.2kW automatic-tool-changer spindle. Assembly is required; expect at least a full weekend. It expands on Millright's earlier Power Route Plus XL.
The Power Route Max's spindle depends on what you order: a router mount with no spindle included, or an optional 1.5kW air-cooled or 2.2kW water-cooled VFD spindle. Check whichever unit you have for its actual RPM against the chart. Its dual ball screws on Y with an auto-squaring gantry and a ball-screw Z axis are built for real rigidity, a step up from the rack-and-pinion Mega V line. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. With the VFD spindle option, the Power Route Max gets close to that bar; with just a router mounted, treat it more conservatively and take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. This machine's spindle depends on what you order, so check the RPM on your spindle's plate or VFD readout and use that number if it differs from 16,000. With the bit maker's 0.025mm per tooth (0.0010 in), at 16,000 RPM: 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Power Route Max ships with a choice of control system: order it with the GRBL Control System to connect over USB through the free Easel Driver, install the driver on your Mac or Windows computer, design in the browser, and use the Carve button to walk through homing, zeroing, and carving. Order it with Masso G3 Touch Control instead and you get a standalone industrial touchscreen controller; Easel's real-time carving connects to machines over USB through GRBL controllers, so the Masso option does not connect through the Easel Driver the same way. Choose GRBL at checkout if you plan to run this machine with Easel. In Easel's menu, select 'Power Route Max' to size the canvas to its 1275 x 1275 x 158 mm working area; the 'Power Route Max (non-GRBL)' entry is for machines ordered with Masso control.
