Mid-size CNC with ball screws and a choice of GRBL or Masso control
The Power Route Plus has a 630 x 630 x 120 mm (24.8 x 24.8 x 4.7 in) working area with 5.5 in gantry clearance. It's a redesign of Millright's original Power Route, now running 16mm precision ball screws on X and Y (dual on Y) and a 12mm precision ball screw on Z, and ships with a router mount for the DeWalt DW618 (router not included) or an optional 1.5kW 120V ER20 VFD spindle.
The Power Route Plus's spindle depends on what you order: a router mount with no spindle included, or an optional 1.5kW ER20 VFD spindle. Check whichever unit you have for its actual RPM against the chart. Its dual ball screws on Y and a ball-screw Z axis are built for real rigidity, a step up from the rack-and-pinion Mega V line. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. With the VFD spindle option, the Power Route Plus gets close to that bar; with just a router mounted, treat it more conservatively and take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. This machine's spindle depends on what you order, so check the RPM on your spindle's plate or VFD readout and use that number if it differs from 16,000. With the bit maker's 0.025mm per tooth (0.0010 in), at 16,000 RPM: 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Power Route Plus ships with a choice of control system, and it says exactly that at checkout: order it with the GRBL Control System to connect over USB through the free Easel Driver, install the driver on your Mac or Windows computer, design in the browser, and use the Carve button to walk through homing, zeroing, and carving. Order it with Masso G3 Touch Control instead and you get a standalone industrial touchscreen controller; Easel's real-time carving connects to machines over USB through GRBL controllers, so the Masso option does not connect through the Easel Driver the same way. Choose GRBL at checkout if you plan to run this machine with Easel. In Easel's menu, select 'Power Route Plus' to size the canvas to its 630 x 630 x 120 mm working area; the 'Power Route Plus (non-GRBL)' entry is for machines ordered with Masso control.
