Mysweety CNC
Mysweety CNC 3018 MAX
Compact desktop CNC router with a 200W spindle
Mysweety CNC 3018 MAX machine photo
The Mysweety CNC 3018 MAX is a compact desktop router with a 200W spindle (rated 200W, up to 300W max) running at 12,000 RPM, a stepper motor rated 1.3A/0.25N.m (42 x 48mm), and a T8 lead screw drive with a double copper anti-backlash nut. It connects with GRBL control and includes an offline controller. Mysweety's own listing gives two slightly different working-area figures for this machine (see warnings); the Specifications table's 300 x 180 x 40mm (11.8 x 7.1 x 1.57 in) figure was used here.
The 3018 MAX's spindle runs at 12,000 RPM, in range for most of the chart. It's a small machine on a T8 lead screw drive, so even with a capable spindle, treat it as light-duty: a truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. This machine's size and drive system fall well short of that bar, so take shallow passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM, but this spindle tops out at 12,000 RPM, so run 12,000. With the bit maker's 0.025mm per tooth (0.0010 in): 12,000 x 0.025 x 2 = 600 mm/min (24 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
300 x 180 x 40 mm (11.8 x 7.1 x 1.57 in)
200W spindle (up to 300W max)
1.3A, 0.25 N.m (42 x 48mm)
T8 lead screw, 4mm lead, double copper anti-backlash nut
The Mysweety CNC 3018 MAX connects to your computer over USB through the free Easel Driver: install the driver, plug the machine in, and Easel talks to it in real time. It also ships with an offline controller for standalone use, but Easel's real-time carving uses the USB connection. You design in the browser, Easel generates the toolpaths, and the Carve button walks you through homing, zeroing, and starting the cut. Select CNC 3018 MAX from Easel's machine menu during setup and the canvas is sized to the machine's working area.
