Openbuilds
Openbuilds LEAD CNC Machine 1010
730 x 810 mm lead-screw CNC with a BlackBox X32 controller
OpenBuilds LEAD CNC Machine 1010
730 x 810 x 100 mm (29 x 32 x 4 in)
Not included; requires a router (OpenBuilds recommended a 65mm compact router, 710W)
NEMA 23, High Torque Series
Lead screw driven on all axes
BlackBox Motion Control System X32
OpenBuilds has shut down, but the LEAD CNC Machine 1010 stays selectable in Easel for existing owners. It shipped with a BlackBox Motion Control System X32 controller; OpenBuilds documents BlackBox elsewhere as running grblHAL, a GRBL-compatible firmware, but this is not stated on the machine's own product page, which never uses the word GRBL. Easel's real-time carving works with GRBL controllers over USB, so this machine's Easel Driver connection is not confirmed here. It is selectable in Easel's menu as 'Lead CNC 1010,' which sizes the canvas to the machine's 730 x 810 x 100 mm working area, but a human should confirm grblHAL compatibility and the actual connection method before publish.
