Openbuilds
Openbuilds MiniMill CNC Machine
Small-format lead-screw CNC, bring your own router
OpenBuilds MiniMill CNC machine
120 x 180 x 80 mm (4.5 x 7 x 3 in)
Not included; requires a router (OpenBuilds recommended a 65mm compact router, 710W)
NEMA 23
Lead screw driven on all axes
BlackBox Motion Control System X32
OpenBuilds has shut down, but the MiniMill stays selectable in Easel for existing owners. It shipped with a BlackBox Motion Control System X32 controller; OpenBuilds documents BlackBox elsewhere as running grblHAL, a GRBL-compatible firmware, but this is not stated on the machine's own product page, which never uses the word GRBL. Easel's real-time carving works with GRBL controllers over USB, so this machine's Easel Driver connection is not confirmed here. It is selectable in Easel's menu as 'Mini Mill,' which sizes the canvas to the machine's 120 x 180 x 80 mm working area, but a human should confirm grblHAL compatibility and the actual connection method before publish.
