Belt-driven large-format CNC bundle based on the open-source WorkBee design
Openbuilds has shut down and no longer sells this model, but it remains fully supported in Easel for existing owners. The WorkBee 1510 has an 824 x 1280 x 76 mm (32 x 50 x 3 in) working area and GT3 timing belt drive on all axes, based on the open-source WorkBee design by Ooznest's Ryan Lock. It was sold as a bundle: motors, the BlackBox controller, and a spindle (RoutER11 or DeWalt DWP611) were order-time add-ons, not included by default.
The WorkBee 1510 was sold as a bundle: motors, the controller, and a spindle were all order-time options rather than included parts, so its actual RPM and rigidity depend entirely on what the original builder chose. GT3 timing belts drive this machine instead of lead screws, which trades some rigidity for speed, and OpenBuilds' own accuracy spec for this model is looser than its lead-screw siblings. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. This belt-driven, largest-footprint machine in the lineup falls well short of that bar unless heavily built out, so take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM: since this machine was sold without a spindle included, check your router's plate or speed dial for its actual RPM and use that number instead. With the bit maker's 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
OpenBuilds has shut down, but the WorkBee 1510 stays selectable in Easel for existing owners. The BlackBox Motion Control System was an order-time option on this bundle, not included by default, so not every unit shipped with it; OpenBuilds documents BlackBox elsewhere as running grblHAL, a GRBL-compatible firmware, but this is not stated on the machine's own product page, which never uses the word GRBL. Easel's real-time carving works with GRBL controllers over USB, so this machine's Easel Driver connection is not confirmed here. It is selectable in Easel's menu as 'Workbee 1510,' which sizes the canvas to the machine's 824 x 1280 x 76 mm working area, but a human should confirm the actual controller and connection method before publish.
