Two Trees
Two Trees TTC450 Ultra
Desktop CNC router with a 500W spindle and dual 12H linear rails
Two Trees TTC450 Ultra machine photo
The TTC450 Ultra is Two Trees' 460 x 460 x 100mm (18.11 x 18.11 x 3.94 in) desktop router. It ships with a 500W spindle stated to run 8,000 to 30,000 RPM depending on installation, and it rides on dual 12H linear rails for rigidity, controlled by GRBL.
Two Trees states the TTC450 Ultra's 500W spindle runs 8,000 to 30,000 RPM depending on installation, without a single fixed maximum, so check the plate on the spindle you actually have before you start. Dual linear rails on all axes make this a stiffer machine than a lead-screw desktop router, so it holds a cut better and resists deflection more than a lighter machine would. Depth per pass is still where the machine's build sets the limit: a truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Work up to deeper passes gradually rather than assuming the machine can take a full-diameter cut right away. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. Two Trees states this spindle's range as 8,000 to 30,000 RPM depending on installation rather than one fixed maximum, so check the plate on yours; the example below keeps the generic 16,000 RPM chart value. With the bit maker's 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
460 x 460 x 100 mm (18.11 x 18.11 x 3.94 in)
500W spindle (8,000-30,000 RPM depending on installation)
Dual 12H linear rails
The TTC450 Ultra is a GRBL machine, so it would connect the same way other Two Trees CNC routers do: over USB through the free Easel Driver, with design happening in the browser and the Carve button walking you through homing, zeroing, and starting the cut. It is not selectable in Easel's machine menu yet, though. Engineering has been asked to add TTC450 Ultra so the canvas can be sized to its 460 x 460 x 100mm working area.
