Larger-format CNC router with a 500W spindle and ball-screw drive
The TTC6050 CNC is Two Trees' largest desktop router, with a 600 x 500 x 100mm (23.6 x 19.6 x 3.9 in) working area. It runs a 500W spindle motor at up to 12,000 RPM, driven by linear guides and ball screws on all three axes.
The TTC6050's 500W spindle tops out at 12,000 RPM, in range for most of the chart. Ball screws and linear guides on all three axes make this a stiffer machine than a lead-screw desktop router, so it holds a cut better and can push a bit more feed rate before it chatters. Depth per pass is still where the machine's build sets the limit: a truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Work up to deeper passes gradually rather than assuming the machine can take a full-diameter cut right away. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM, but this spindle tops out at 12,000 RPM, so run 12,000. With the bit maker's 0.025mm per tooth (0.0010 in): 12,000 x 0.025 x 2 = 600 mm/min (24 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The TTC6050 CNC connects to your computer over USB through the free Easel Driver: install the driver, plug the machine in, and Easel talks to it in real time. You design in the browser, Easel generates the toolpaths, and the Carve button walks you through homing, zeroing, and starting the cut. Select TTC6050 CNC from Easel's machine menu during setup and the canvas is sized to the machine's 600 x 500 x 100mm working area.
