Onefinity
Onefinity Apprentice Series
Entry-level CNC router with an open-loop Redline RTS-1 controller, 16.5in x 16.5in working area
Onefinity Apprentice Series machine photo
The Onefinity Apprentice Series is Onefinity's entry-level CNC, with a 16 1/2in x 16 1/2in x 5 1/4in working area (423 x 423 x 114mm). It drives X and Y on a 1610 ball screw (10mm per revolution) and Z on a 1004 ball screw (4mm per revolution), with NEMA 23 stepper motors (1.2 Nm) on every axis riding 30mm hardened-steel linear shafts. No router or spindle ships with the machine: Onefinity designed it for a Makita RT0701C trim router or an optional 65mm Redline spindle.
The Apprentice doesn't ship with a spindle: it's designed around a Makita RT0701C trim router or an optional 65mm Redline spindle, so check whichever unit you use for its actual RPM range before you dial in a cut. The machine itself is Onefinity's lightest, entry-level frame: NEMA 23 steppers on 1610/1004 ball screws and 30mm linear shafts, built to be rigid for its price point but still a step below the closed-loop Elite Series. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. The Apprentice's lighter build means shallower passes are the safer default: push too deep for the bit and spindle you have and it will deflect and chatter, leaving scalloped edges, or rub instead of cutting and burn the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM; since the Apprentice doesn't include a spindle, check your own router or spindle's plate for its actual maximum and cap the RPM there if it's lower. With the bit maker's 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
16 1/2 x 16 1/2 x 5 1/4 in (423 x 423 x 114 mm)
Not included; designed for the Makita RT0701C or an optional 65mm Redline spindle
NEMA 23, 1.2 Nm
1610 ball screw on X/Y (10mm per rev), 1004 ball screw on Z (4mm per rev), 30mm hardened-steel linear shafts
RealTime CNC RTS-1 Open Loop Motion Controller
Onefinity lists the Apprentice Series controller as a 'RealTime CNC RTS-1 Open Loop Motion Controller' running free PC-based control software, not GRBL. Easel's real-time carving connects to machines over USB through GRBL controllers, so the Easel Driver would not connect to this machine as sold even once it is added. This machine is not yet selectable in Easel's machine menu: it is currently sold on Onefinity's site as an entry-level 16.5in x 16.5in spindle CNC router, but has no matching Easel menu entry yet, and engineering has been asked to add it.
