Onefinity
Onefinity Original Series X-35
Entry CNC in two cut areas on 35mm rail tubes with an optional Buildbotics controller
Onefinity Original Series X-35 machine photo
Onefinity didn't state a stepper motor spec for this generation, and no spindle ships with the machine, so check your router or spindle's actual RPM plate before you set feed rate. The mechanical build is real but modest: two 35mm rail tubes with sealed linear bearings and ball screws on every axis, not a heavy industrial gantry. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Without a stated stepper spec to confirm that torque, lean conservative and take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM; since the Original Series X-35 doesn't include a spindle, check your own router or spindle's plate for its actual maximum and cap the RPM there if it's lower. With the bit maker's 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on this machine. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
Woodworker: 32 1/8 x 32 1/8 x 5 1/4 in; Machinist: 16 x 16 x 5 1/4 in
Not included; designed for the Makita RT0701C 1-1/4 HP compact router
Two 35mm hardened-steel rail tubes, sealed linear bearings, ball screws on all axes
BB Buildbotics controller
Onefinity no longer sells the Original Series X-35, but it stays selectable in Easel for existing owners. Its optional controller is a 'BB Buildbotics controller,' not GRBL, so Easel's real-time carving, which connects to machines over USB through GRBL controllers, does not connect to it as sold. It is selectable in Easel's machine menu as Woodworker X 35 (Buildbotics) or Machinist X 35 (Buildbotics) depending on your cut area, which sizes the canvas to that size's working area, but confirm the actual connection method with Onefinity or the Buildbotics community before relying on Easel to carve with this machine.
