Onefinity
Onefinity Pro Series
Large-format CNC in three cut areas with a Buildbotics controller and open-loop steppers
Onefinity Pro Series machine photo
Woodworker: 32 1/8 x 32 1/8 x 6 1/4 in; Journeyman: 48 1/8 x 32 1/8 x 5 1/4 in; Foreman: 48 1/8 x 48 1/2 x 6 1/4 in
Open-loop high-torque steppers (axis placement differs by size: see machine-overview)
1616 ball screw on X (16mm per rev), 1610 ball screws on Y/Z (10mm per rev); Foreman adds a Z-20 Z slider with 165mm travel
BB Buildbotics controller
Onefinity no longer sells the Pro Series, but that isn't the reason it won't connect through the Easel Driver: Onefinity lists its controller as a 'BB Buildbotics controller,' not GRBL, and Easel's real-time carving connects to machines over USB through GRBL controllers. For existing owners, it stays selectable in Easel's machine menu as Pro Series Foreman, Pro Series Journeyman, or Pro Series Woodworker depending on your cut area, which sizes the canvas to that size's working area, but confirm the actual connection method with Onefinity or the Buildbotics community before relying on Easel to carve with this machine.
